TPMS issues
WTFOT
Thomasville, GA
TPMS is likely 315 mhz and is the same frequency for most remotes example garage door/gate openers. Thinking out loud...disable garage buttons on visor, this likely the only solution that has continues power. Make sure you don't have any remotes near the vehicle while you troubleshoot, less likely since remotes should die quickly if using battery for power and a button is stuck.
