To supercharge or not???
GoMuscles
Houston
Why? I get the whole NA thing, but really to me a supercharger is a viable option. The reason I have the money I have is because I don't spend it senselessly. Other then personal opinion, is there a reason that a supercharger is not a viable option?
. I went the way of the the whipple so I could also build a motor underneath it. I'm with some of these old school guys and i agree there's no replacement for displacement but the whipple is good for 1200hp and I'm sure 99.9% of us have no need for that much power but its cool to know the ceiling is so high. Also another positive is with a built motor and blower you'll be able to reprogram and adjust power for what you need farly easily. Go from mild to wild in a hr or two.
As for dirt and dust I haven't had one issue and I have about 5k miles desert driving between Hobbs NM and Andrews Tx. I run my truck like it was built to and try not to push it to hard bc the power of the 6.2 stock is all or more the stock suspention can handle.
I liked the idea of the blower bc it allowed me to get to my power goals faster while taking my time building the 6.6L God knows we all would like to see more aftermarket options for the 6.2L.
The blower should be looked at as a component to a system not a one and done. For most this is enough bc these guys are right they don't see much dirt but man I'm telling you it's a ******* blast to drive! I'm glad I did it first bc now the truck is a damn roller coaster on and off the road.
In the end the blower makes play time everytime your behind the wheel not just when your huckin or trailing.
---------- Post added at 12:05 PM ---------- Previous post was at 12:02 PM ----------
Though there are desert race trucks that are forced induction and do fine, I've heard too many horror stories about FI trucks having major issues off-road, especially in very dusty/sandy areas. That's my take. For me $ better spend on internal engine components
But weren't they all Hennescrewed?
---------- Post added at 12:08 PM ---------- Previous post was at 12:05 PM ----------
Because F/I builds heat in optimum conditions - off road wheeling only makes heat buildup worse. The only way I would consider running F/I in the conditions the Raptor was designed for would be centri or even better, turbo and I'd have forged internals.
There are several Raptors that have had engine fires because of running top mount superchargers in very high load conditions.
So a 600hp na motor runs cooler than a 600 FI motor?
If this is always true then why did Ford make the ecoboost? Why do desiel trucks idle all day no issues? I know these are turbos but the tech that's out now with upgraded cores and heat exchangers its all good. If you beat on anything it's gonna get hot.
Maxx2893
Rock and Roll Offroad
Burleson, TX
To answer you question, yes. Much cooler in fact. There is a huge reason why you have huge intercoolers for FI. There is much much more heat soak in the engine bay with FI
A
Az Scooter
The reason that there are large heat exchangers is because engines run better with cooler air. It has nothing to do with the heat an engine generates.
I have considered some suspension upgrades, but I want power first. I have a pretty good idea of what I want on that end. Part of my thing is that I don't want to mess with the day to day driveability of the truck by messing with the suspension in an unmeasured way. Right now, if we go somewhere, my wife would rather go in the Raptor then her 13 Avalon, if nothing else, just for the ride, and the Avalon isn't bad.
Deinonychus
Jacksonville, FL
Bet my Raptor has a better street ride than yours, not to mention off road.
A
Az Scooter
I didn't say nothing would be done. I said I wanted to take a measured approach.
WarSurfer
DC
An N/A engine can run hot just like anything else if not built for the conditions it operates in.
F/I engines DO generate more heat, that's why intercoolers are needed. The Eco isn't a very good example because it's designed for forced induction the 6.2 is not. You'll notice on the Eco Baja racers they ran HUGE intercoolers and large charge piping to reduce the intake temps.
Idling all day is a far cry from running at 5 grand for hours on end.
I never said you couldn't run F/I off road, I said you had to be smart about it - forged internals, large FMIC and a well designed cooling system are mandatory.
Boss Hoss
Colleyville, Texas
There is a difference between a TC and a SC engine. :cocktail:
You run a SC engine set up for high HP on our place in Eddy County HM it is going to well imagine this---after just one day and the outside temps are over 110 you open the hood and everything is white!! I mean everything!! Do this on a constant basis or even close to it you are asking for trouble. Inagine what the HE will look like after enough of that horrid fine dust coats it over and over--can you cay Heat Will Not Be Exchanged very well. It is a real bitch to get it washed off completely as well.
WarSurfer
DC
Absolutely false. F/I engines do generate more heat under the same conditions as N/A. Intercoolers exist because those engines would burn up if they didn't have a way to reduce the heat generated from compressing the air.
An unavoidable side-effect of forced induction is that compressing air, as stated in the first law of thermodynamics, raises its temperature .[1] As a result, the charge density is reduced and the cylinders receive less air than the system’s boost pressure prescribes. The risk of detonation, or "knock", greatly increases. These drawbacks are countered by charge-air cooling, which passes the air leaving the turbocharger or supercharger through a heat exchanger typically called an intercooler. This is done by cooling the charge air with an ambient flow of either air (air-air intercooler) or liquid (liquid-to-air intercooler). The charge air density is increased and the temperature is reduced. In this way an intercooler can greatly increase the ability to run higher absolute compression ratios and take full advantage of using compressors in series. The only drawback of intercooling is its mass and volume of the cooler along with the associated plumbing and piping.
http://en.m.wikipedia.org/wiki/Forced_induction
---------- Post added at 02:05 PM ---------- Previous post was at 02:01 PM ----------
I am well aware of the differences between TC, top mount SC and centri SC.
I agree with the sentiment on particulate buildup. I think the Eco race trucks ran the intercoolers in the back with the radiators but you point is well taken. I should have said IC or HE not FMIC.
