The SnoBall-2014
Hockster
My 45ft Bluewater Party
Winchester, Va
I will bring tools and help you put it in. :)
---------- Post added at 08:36 AM ---------- Previous post was at 08:26 AM ----------
I suppose i could look into putting my winch on seeing as i bought it before snoball last year and its still sitting on the shelf in the garage. It's on a receiver mount right now so it could be brought along with a battery and used that way.
I cant believe we are only 12 days away.
I made a long set of jumper cables that plug in the winch and you just clamp them onto the truck using the winch.
Yukon Joe
Trafford, PA
Well, I thought I would have a winch. The mount on my Venom winch has mounting holes pre-drilled, and I think they missed center with their template. I got a Warn Zeon that I bought from ADD along with the bumper, but it doesn't look to me like the Zeon will fit, with the holes drilled this far off. Am I missing something here?
The winch should have had the 4"x10" bolt pattern. How did ADD miss this? Ask them when you see them on the run.
Yukon Joe
www.RUNRAPTORRUN.com
---------- Post added at 12:51 PM ---------- Previous post was at 12:50 PM ----------
:hidesbehindsofa: I'm still not going... just saying
I believe NC needs a copilot.
Yukon Joe
blockdoc
Lexington, KY
Yukon Joe
It does, and the hole pattern is correct - the winch will mount up to those holes. They're just shifted laterally about 1.25", so the winch would be off center & not sit in the spot for it.
I just bought a cobalt bit to drill new holes, making a template & drilling them properly in a minute.
96,364
60,273
NTXRaptor
