Texas Raptor Run April 13-15
whtrapta
Ostrich Wrangler
Bolivar/Springfield, MO
No need really to have it locked. IDK. Last time I locked it up I snapped my drive shaft 4 hours from my house. So i'm still leery on it. I might though. You can still get this truck plenty sideways unlocked. Plus the wear on tires is probably a little less.
keatonskidmore
were you on dirt or pavement when you snapped it? how did it happen??
whtrapta
Ostrich Wrangler
Dirt. Sand. Just went into a power slide and BAM! done. It was a manufacture defect so everything was covered. There are only 2 cases of it ever happening though. Me being one of them.
keatonskidmore
i see..i put a few power slides on it the other day and have done quite a few with it before..That is pretty bad that you were one of the two cases but pretty good odds for the rest of us! haha
whtrapta
Ostrich Wrangler
Ya I wouldn't worry about it.
---------- Post added at 11:27 PM ---------- Previous post was at 11:26 PM ----------
Everyone needs to convince etalian2005 to come out to the run. He currently doesn't have a raptor, but who cares. He's a member and lives in the area. Get your butt there!
keatonskidmore
He can do a ride a long with sprsnk! haha
SPRSNK
I Void Warranties
Franklin, TN
2wd is more fun, but you really need to know how to control a vehicle and not be scared of getting sideways. 4wd will give a lot of control you would not have. Our trucks also will overheat the transmissions at high rates of speed in 4wd. Having never done this course before, I shall be playing around with both.
I drive in 2wd, Off Road mode turn on, Traction control off. Most of the time.
Guns: I'll probably have 5-6 myself.
KaiserM715
Kaiser Söze
I talked to Trey earlier today about a few things. I am cutting #'s out for everyone's truck (Vinyl). No, you can't pick your numbers. They will all be white (I have about 80 yards of white vinyl sitting around). If you have a white truck, they'll go on your rear door windows. [snip] ...your name as well to stick on your truck. I am cutting these to go on the top of the drivers side door.
How about having them setup to go on everyone's rear door window? The factory tint will provide a nice contrast and then they will be on the same location for each truck.
