SVC Intercooler
Wfo
Syracuse
So SVC got back to KHC (who I bought the IC through) and told them that I need a different bracket for the 2019 ACC. They have shipped it out to me today.
You may have to have it aligned or recalibrated at the dealer after install. The tech package is a pain.
Kahuna
THE MORE YOU PLAY WITH IT, THE BIGGER IT GETS
Hoping on ******** Forscan for the win
Syracuse IN
Just ordered my SVC FMIC kit today. Spoke with Jeff and he was very informative and was very helpful. Stoked and can’t wait for it to arrive! Gonna be putting on the ADD bolt on front bumper at the same time. For anyone that has installed the SVC intercooler on a 2019 is there anything from the factory that I need to cut other than obviously the shutter system on the grill?
Syracuse IN
Ok so just got my intercooler today and everything looks great but no instructions! I mean I’m a good mechanic so I’m sure it won’t be a issue but the part I would like to actually see is exactly how the 2019 ACC bracket from SVC looks installed. I want to make sure I put the bracket together correct. It’s in multiple parts. Any help??
Syracuse IN
Once you get it apart it easy to figure out. I don’t have the acc
yeah the ACC bracket is the only part I’m not positive on how it goes. The pics I’ve found online show it in the center on top of the intercooler but are all to far away and I can’t make out the details of it in the pics.
Wfo
Syracuse
Give SVC a call, they are great guys and can clarify any questions you have.
Raptor911
Ashburn, VA
I am looking into SVC's FMIC and I have some questions for the guys that have installed this (#WFO, #Jesse Atteberry and #zombiekiller)
1 - The BOV will vent to atmosphere with this SVC's IC. What happens to the oem pipping? Does SVC provide a plug for the pipe?
2 - The OEM IC and fan will be removed when installing FMIC. What does one do with the harness that use to plug into the Fan?
3 - I assume the SVC's FMIC will be supported by the OEM IC upper metal bracket. Do you have to modify it like seen in this video >>
4 - There is a rubber mat surround (above the oem bumper and below the grill), do you just completely remove this?
5 - The image of the FMIC at SVC's sight does not show any upper bracket whatsoever. There must be one right or how does one secure the top of their IC?
Any insight will be helpful. Thank you!
svc
Worldwide
Thanks for the questions
Yes the BoV vents to atmosphere, the oem return tube is removed and a cap is provided for bottoms of intake.
The fan is unplugged and the harness is zip tied up outta the way.
We provide a new upper and lower mount for the Ic and the upper mount had a tab to bolt the new ACC relocation kit to it . The rubber mat is also removed
Wfo
Syracuse
Thanks SVC for answering. It is a very high quality piece and I would buy again. Quality and customer service is SVC’s strong suit, no need to go anywhere else only to find the others don’t stand behind their products to the level SVC does.. better grab a Baja bumper to go with that!!
