So this weekend I decided to finally install my new SVC Adjustable Bump System. I figured since I had 4 days off of work, I should be able to get it in, no problem.
Well, everything started out ok, it is really a nice kit. I used a flapper wheel on a grinder to smooth out the welds on the frame, then painted the frame to keep it from rusting.
Installation went pretty well, I followed the instructions provided, there needed to be a few changes made. Then Gen 2 system uses 3 5/8 bolts, where the Gen 1 uses (1) 5/8 bolt, and (1) 3/4" bolt.
Also the exhaust hangers needed to be cut, as the Gen 2 bracket covered the bottom hole for the hanger. I would rather cut the hanger than try to cut through the ABS bracket. On the right side I needed to remove the exhaust pipe to get better access to the hole in the frame.
The right side exhaust pipe should be removed to get better access.
I used about twice as many tools as called out in the SVC instructions, and being the OCD kind of guy I am, it took me honestly 8 hours to do the complete install. Someone else might be able to do it in half the time.
This is a really nice kit. I would recommend it to anyone.
