Strut extension vs spring perch collar
Finnster
Ashburn, VA
Quick question.
Wouldn't this strut extension maintain stock ride quality better than a spring collar? I only ask because in my mind, the spring collar adds preload to the spring where these would still give the 1.5" leveling without preload.
http://www.cjponyparts.com/readylift-leveling-strut-extension-kit-1-1-2-inch-f-150-raptor-2017/p/662715/
Has anyone done these?
Disregard. I see this has been addressed in a previous thread.
khcdave
South Brunswick NJ
You have to be careful with leveling spacers that push the shock down extending the droop travel. The suspension is limited by the shock and with that style leveling kit the suspension will droop to far damaging cv's and tearing the boots when running in 4wd. The best option for the raptor is the collars so the travel stays the same. The 1.5 lift collars do not noticable affect ride quality since the shock stays in the bypass zone and technically preload does not change the overall spring rate. If you need any help let us know.
Dave
FatBuoy
Dave
This logic would NOT apply to new springs, like Eibach, correct?
Aaron
Meme Corps Commandant
WA
The ride zone would...same amount of lift so the piston would be in essentially the same spot as with a spacer. However with lift springs you're going to have a stiffer spring rate in order to achieve the lift.
xrocket21
Maine
It is the case with the eibachs, but you dont necessarily have to have a stiffer rate. you could have the same rate but a longer spring.
khcdave
South Brunswick NJ
As others said new coils will achieve ride height change either through higher spring rate or longer coil but still keep you in the same shock travel range. This way you are not over drooping like a strut spacer will do.
F
Finnster
Ashburn, VA
I installed the RPG 1.5. I'm happy with the end result. Not perfectly level but I prefer it that way.
