Do these amazing plugs require the "weep hole" mod for the stock tuned engine?![]()
Every time this is typed, new sasquatch77 has to fight itself to stay in lurk mode. It wants desperately to poison the forum, but has grown weary of being repeat banned 3 times now.
weep hole was always bunk anyway. bunk, bunk, bunk.
c’mon, you know you want to sasquatch77. We know you’re watching.
Come out of hiding, so we can get your new ID banned.
just did the plugs in my 18 SCrew
1)new plugs came gapped at .028
2)its an easy DIY job - engine cover comes off with 2 10mm bolts, 8mm bolt for each coil pack, and spark plug socket with short and medium extension to remove the plugs. Much easier access than an LS motor
3)old plugs at 1600 miles burned with clean electrodes
4)I did not disconnect the battery or reboot the ECU
impressions - a must do. The engine is much smoother and no more stutter on acceleration. Idle is smoother as well. This is a must do IMHO, truck should come from the factory with these plugs
So would you say the stock plugs were burning clean and at the right temperature? What was the gap?
Reason I'm asking is because putting colder temp range plugs in should cause buildup if the old ones weren't running too hot. Also, if the new ones are gapped well at 28, and the old ones were worn and not gapped right to begin with, that could part of the difference you're seeing.
