Snapped something
gbrown27
Auburn, Al
I was pulling into a parking spot like normal and I heard something snap and my truck hunched over to the side so I got out and saw this...any idea on how much damage this is?
Hazzard
Southwest MI
Probably new upper control arm and spindle aka (knuckle) is needed. Might be simple and just a upper ball joint though u never know till u tear into it.
Huck
Chicago Sw Burbs
Looks like just the pin snapped. Hit up Rpg for some new ones and done. Or did the uniball go too? It's hard to tell from the pic
Just the pin. No worries.
Mil T
Payson, Az
Call RPG and Corey will take care of you. This happened to me also. If your pins where the reddish color
then those were recalled. RPG will replace them for you.
Believe me when I say, you are VERY lucky it happened where it did and not that much damage was done. Your going to have to replace the other side also.
This is what could have happened.
TXRPTOR37
Makes you realize the importance of your UCA's and pins
Mil T
Payson, Az
Yes it does. When mine broke, I lost all braking and the steering was gone. Luckily I was on a good road and only doing about 35 or 40 but I was headed over the edge and was able to force it into the ditch.
As you can see the only thing that was holding the wheel on was the abs sensor line.
Mil T
gbrown27
gbrown27
Auburn, Al
Damn I'm glad i was just parking. I'll call RPG tomorrow and take care of it, Thanks for the response guys
San Diego, CA
Like everyone said, it looks like just the pin broke. That is the best case scenario for this kind of issue.
FYI the first thing RPG will ask is how tight you torqued that bolt. It loooks to have snapped from the head so that is normally an indication of too high of torque. That may not be the case, and I am not accusing you of anything, but it is good to have all the info when calling.
