Security Systems
p3rs1st
Davenport, IA
Looking forward to install video.. I've added everything I can think of to my Amazon cart..Would this list cover everything? Not sure if I'll attempt to DIY or if I would just order all the parts then take it to a Viper dealer here in town (best buy or a local shop)
$300 - VIPER 5904V FULL FEATURE CAR ALARM WITH REMOTE START AND HD COLOR 2-WAY PAGER
$44 - Install Essentials 530T Window Automation System
$25 - Install Essentials 507M Tilt Sensor -
$13 - Directed Electronics 506T I.T. Audio Sensor
$22 - Directed Electronics 520T Back-Up Battery System
$75 - XpressKit Nexgen DB-ALL Transponder Bypass/Doorlock Interface. DATABUS ALL MULTI MODULE VSAFE.
JuggNuttz
chicago
i dunno if it was asked already, but is there a security system that doesnt include remote start, that will work with the oem remote start and key? thats one thing that has me hesitant, i dont mind a fob, but i dont wanna turn off the alarm if i want to start my truck, or it will set off the alarm kinda thing.
The Car Stereo Company
here, on frf
alright guys, i am getting into the install and have noticed a bit of complications with the trucks wiring. i will have a video up, but it is going to take longer than i expected. also, my computer here sucks terribly and i can not access xpresskits login page to program the dball. i might have to get a new shop computer..... damn.... sorry for the delays guys, but at least you all wont have to go through all the head scratching i am going through right now.
SrBug
Houston
This is a summary of wire connections to be done ,
Please Feel free to Correct me .
A - 5 wires to BCM:
White #5 From 6pin Main on Alarm module aka "Parking Lights" ( + ) to BCM Gray 10pin,------------------------------pin#6
Red/Black #4 From 12pin Red on DBaLL module aka "Unlock Activation" ( - ) to BCM Gray or Black 26pin,Yellow/Violet--------pin#8
Green/Black #2 From 12pin Red on DBaLL module aka "Lock Activation" ( - ) to BCM Gray or Black 26pin,Blue/Green-----------pin#6
Yellow/Red #11 Fron 14pin Blue on DBaLL module aka "Door Pin " (n/a) to make bypass, connection, bcm side
Orange/Red #10 From 14pin Blue on DBaLL module aka "Door Pin " (n/a) to make bypass, sw. side
B - 2 Wires to P.A.T.S:
Orange/Black #11 From 12pin Red on DBaLL module aka "Data RX" (n/a) to P.A.T.S./4pin, Violet/Grat-------------------pin#4
Yellow/Black #10 From 12pin Red on DBaLL Module aka "Data TX" (n/a) to P.A.T.S./4pin, Yellow/orange-----------------pin#3
C - 2 Wires OBD II :
Tan/Black #3 From 14pin Blue on DBaLL module aka "HSCAN-Hi " (n/a) to OBDII port Gray/Orange-------------------pin#3
Tan #4 Fron 14pin Blue on DBaLL module aka "HSCAN-LOW" (n/a) to OBDII port Violet/Orange-----------------pin#11
D - 2 wires KeySense :
Pink/White #7 From 10pin Black on DBaLL module aka "keySense Input" ( + ) to IGN SW.Black/7pin,---------------------------pin #5
Gray/Black #7 From 12pin Red on DBaLL module aka "KeySense/Accesory Output" ( + ) to >diode>to IGN SW.Black/7pin,-----------------pin #5
E - 2 wires to IGN.SW. :
Brown #7 From 14pin Blue on DBaLL module aka "12V" ( + ) to IGN.SW.Black7pin,Blue/Red or Green/Red-------pin #4
Yellow #8 From 14pin Blue on DBall module aka "IGN" ( + ) to IGN.SW.Back7pin,White/Orange,----------------pin #1
F- 1 Wire to Alarm
Orange/ Yellow #9 From 14pin Blue on DBall module aka "IGN RS" ( + ) to Alarm IGN.1 H3/1,Heavy 10pin plug,pink wire---pin#1
G - 4 wires to IGN.SW.:
Red H1#1 From 6pin Main On Alarm module aka "12VDC Constant input" ( + ) to 12V Always ON or BATT.
Black H1#2 From 6pin Main On Alarm module aka "GROUND" ( - ) To Body Ground
Green H3#5 From 10pin Heavy Plug on Alarm aka " Start input" ( + ) To IGN.SW. Black/7pin,Blue/white wire-------pin#7
Diode to be used is IN4004
i hope it makes sense somehow
Don't blame me if you smoke your Rap!!!!!
all this was collected from the install instructions , i have not removed any panel on my truck yet so is not verified
here, on frf
i was not able to access any of this info the last few days. but i think i have it going on another computer so i will let you know
infinitereality
SLC IR/8
Louisiana
I'm curious if the Raptor will retain it's stock unlock lighting? As in the parking lights will remain on for a minute after disarming...
96,966
60,909
53vodich
Latest posts
