Security Systems
The Car Stereo Company
here, on frf
I'm curious if the Raptor will retain it's stock unlock lighting? As in the parking lights will remain on for a minute after disarming...
i believe the courtesy lights come on with disarm, but i will double check that during my install
Is there more information on this?
dei (viper/clifford ect, etc) has a system that uses your factory keyless to trigger their alarm system. the problem is expanding to have multiple channels, also no visual/audible confirmations regarding your vehicles status, as it is your keyfob that activates and deactivates the add on system.
SrBug
Houston
i need to verify these
Orange/ Yellow #9 From 14pin Blue on DBall module aka "IGN RS" ( + ) to Alarm IGN.1 H3/1,Heavy 10pin plug,pink wire---pin#1
and
Gray/Black #7 From 12pin Red on DBaLL module aka "KeySense/Accesory Output" ( + ) to ALARM ACCESSORY 1 H3/3 ORANGE to (>diode>)to IGN SW.Black/7pin,-----------------pin #5
can anyone pitch in
SrBug
Houston
ok i got every thing going as i posted it ,
im at programming with the Bitwriter trying to figure out the settings as i got key on but no crank situation , neutral sw. is ground and safety switch is off,virtual tach is learned,
i ll monkey around with it some more then ill post again.
i got crank out signal from viper but will not crank
SrBug
Houston
Yep i did , the dball seems to be doing its thing
Because ignition turns on,
---------- Post added at 07:25 PM ---------- Previous post was at 07:07 PM ----------
What settings with the bitwriter should be left default?
No aux channels being used yet.
Virtual Tach or Voltage?
here, on frf
virtual tach is the better of the two, but the tach wire can be found very easily. i have already documented that in the video, if you want to use it let me know.
put the key in the ignition (without turning it) and try to remote start. tell me what happens
SrBug
Houston
Pink/white from 10pin black to kesense On ign sw.black7pin blue and gray pin#5
Also gray and black joins them after the diode wich has the band towards the pin#5
Before the diode it splits to Acc1 on alarm as the diagram indicates
here, on frf
im not sure the grey black connects to acc. it is a + output so i dint see a reason to connect to another power source.
---------- Post added at 09:01 PM ---------- Previous post was at 09:00 PM ----------
correction.... i meant the pink/white
96,966
60,909
53vodich
Latest posts
