SPV Parts 2021-2025 Ford F-150 Raptor 10'' LOWER Grille w/Baja Designs S8 Light Bar Kit (Behind Grille)
The NEW Behind the LOWER Grille Light bar Kit by SPV Parts allows you to install a 6", 10" or 12" Light bar in the lower grille opening of a 2021+ Ford Raptor. There is a wide array of options in choosing the combination you want. This kit includes your choice of Baja Designs 10" S8 Light Bars...
Taking a little more time on this Raptor to get the lights the way I want....first I installed BD S2 lights in the bumper to replace the Rigid OEM ones and put BD S1 on the rear. Nothing wrong with Rigid (ran them on my Jeep), but just prefer the looks and options of the BD lights. Since I could not make my mind up all at once, I installed the Aux Wire extensions from @Specialtyperformanceparts which was a very wise decision as I keep making changes to how I have the lights connected to the Aux Switches and I am sure I will make at least one more change.
Auxiliary (Aux) Switch Wire Extension Kit with Connectors (Numbered)
SPV Parts is proud to present our new Aux Switch Wire Extension Kit. This new kit will extend your Aux switch wires in your Raptor, Bronco, Super Duty, Tremor and other vehicles by about 8 inches. In addition, each includes a single Weather Pack connector installed for quick connect to any of...
On my 2020, I had a BD ONX6+ in the lower grill and 40" S8 behind the upper grill plus BD pocket lights and all white except for a pair of S1 in the bumper pockets. Would light up the world pretty good, but almost too much for where/how I drive. The bumper Factory Amber S2 in Wide Cornering gives a nice wide pattern, but there was a bit of a gap directly in front of the truck. So went with the S8 Factory Amber, Wide cornering and even though 2 of the LEDs are blocked by the trim, it does a great job coupled with the S2's and now I have a consistent pattern all the way from side-to-side.
The SPV brackets are a quality product and great black color match. And the custom harness makes connection a breeze. I did make a few changes during the install. First, I swapped out the silver BD front face screws for black stainless steal screws (M4x12mm). Second, the SPV kits comes with lock nuts and depending on your tools it can be a pain to run them down the long bolt. So I used SS washer, SS lock washer, and SS nut instead....way easier (Home Depot 1/4"). Third, when you pull the front bumper trim pieces, you can re-use the clips. But sometimes the prongs break and if removed a few times like I did they tend to break off. So got these clips from Amazon whcih worked great. https://www.amazon.com/gp/product/B0B7QV96XP/?tag=fordraptorforum-20
A plus that I did not think about upfront was how the S8 backlight worked with the Factory Amber. On my previous truck, the backlight was not all that obvious with the white lens. With the Factory Amber lens, the backlight creates kind of a light glow which makes it more obvious.
UPDATED 12/15/2024:
So I just did not like the two posts in the lower grill trim piece. Further down this thread I documented how I modified it. Then once I had the posts removed, I did not like the "extra" part of the SPV bracket that stuck out toward the center past the mounting bolts. When I had OnX6+ in my last Raptor, it all looked clean because there was a honeycomb grill over the front. Now that it was wide open, it needed to be a little neater to calm the OCD.
So your first thought might be that you don't like the overlap of the two pieces of the bracket. Well I planned to mount the light behind the OEM bumper mounting points and after measuring about 20 times I was confident that I would not see the overlap. And it turned out that I also had a perfect way to hide the tie wrap used to secure the light wire so it would not interfere with the shudders. Here is the final picture with the new shorter brackets and the new trim piece. Much cleaner to me and now see all 8 lights vs. 6.
Next is to mount two more S8 behind the grill.
