Raptor suspension
AaronCarl
west virginia
I have a 2020 raptor I have a slide in the bed where I carry tools it lowers my bed 1.5” I have installed airlift air bags they make the height correct but I am not satisfied with this and I feel it limits the travel of the factory suspension I have been looking at different leaf springs but afraid it would make the ride much stiffer does anyone know one of a engineered performance rear suspension fix
Thank you
Nex
RIP CoronaRaptor
Washington State
Welcome to FRF. Please post pictures of said prius with airbags. There are TONS of suspension threads on FRF. Use the search in the top right of your screen. But you will probably want +2 Deavers.
Zeusmotorworks
Thank you
I went with the Deaver +2 HD’s. They have a higher spring rate, that I initially felt. However, within a week or two I was used to them, and I can throw the boat on the back of the truck and not have the headlights pointed at the sky. In my case it’s worthwhile. It’s supposed to be 450 pounds of increased weight capacity. However, because they’re 11 leafs instead of the OE 4, it’s much more progressive and less felt.
Dunerking
Agua Dulce,Ca
Would the mind trust feel that Deaver +1 still be to soft for the occasional dirt bikes in the bed or hauling a 24’ boat?
Zeusmotorworks
Whether you go with the SD or HD you need the +2 or more depending on your application. Ford was ******* stupid and put a lift block between the axle and spring. +2 is stock height with the dumb **** block removed.
+ 3 is a 1" lift from stock with the block removed.
