Perch Mod Discussion
Mid perch or no?
  • Total voters
    426
LSURaptor
Houston
Handling is a consideration but since I can't really test drive it, it's hard to say if I'd care about the top setting feel vs the middle...
Badrap
Mabank, Texas
Panda says he may need to adjust the headlights down. People seem to be flashing at him like he has the Brights on. Getting mine to Top perch within the next few weeks.
19-Kilo
ΜΟΛΩΝ ΛΑΒΕ!
Boulder, Colorado
one concern is also the angle for the UCA and bolts... the reason Outlaw Raptor makes their Heim UCA is because the stock UCA is not designed to move through its full range of motion (droop and compression) on the top perch; the angle is too steep for the OEM joint.
"The arms are designed to maximize full droop and compression without compermising the Uni ball movement."
LSURaptor
Houston
Well, I don't want to **** other shit up but range of motion shouldn't change, should it?
It's going to spend more of it's time operating in a different range but overall, the travel is still the same.
19-Kilo
ΜΟΛΩΝ ΛΑΒΕ!
Boulder, Colorado
yes the travel is still the same, but the UCA on the top perch will already be extended more than on the stock position. the angle between the spindle and the UCA changes with ride hight.
Raptizzle
FYT
Southern CA
With the increased ride height from the perch adjustment, your OEM joint is now loaded from one direction as opposed to sitting even under the UCA.
Reptar
Jersey
just split the difference and do the middle perch. can't stand the nose up look, truck looks like it has a load of manure in the bed when it's nose up even the slightest bit. Then when you actually do use the truck as a truck and fill the bed, it's going to be even worse.
BIRDMAN
Birdministrator
Boston
The top perch is actually closer to level than the middle or at least it looks that way. Not a noticeable nose high stance at all
Sent from my right thumb using Tapatalk.
