torrin
Negative. Entirely TOO SENSITIVE. Unsafe to drive. Out of curiosity, I did it for about 1/4 mile. Immediately removed it.
Not technically correct. It will work as well (or as bad) as without the tune. It just maps the throttle response higher by making it look like your mashing the gas pedal when you are not. MPT is an aggressive tune with throttle response, so it is likely be be nearly undrivable, but it "works"
