dkfc13
HPA Systems LLC.
They key to taking these off is to have a quality hardened torx bit. The only time I have stripped torx bolt heads was when I was using a cheap bit. When the bit starts to round off, you loose engagement with the bolt head and that is when you strip it.
There are a few of us that have had good luck with an air ratchet. It will give you enough torque to break the loc-tite but not strip the bolt head. @WRCRaptor
