Ford Performance Bead Lock Ring Coating
XSTNKT
Michigan
Anodizing would be the ticket for sure. Very durable and a nice "machined" effect you just can't get with powdercoat or paint. You could black oxide the bolts too, if they're not already coated...
Antho
I'm guessing there is going to be a specific beadlock Ring just for this wheel? Kind of wild that they did that at the bolting surface.
ToadSmasher2K1
ToadSmasher2K1
Home Is Where You Make It
Red Kingdom
I’m not sure how that is going to work though. The bolts holes are not all on the same plane, the beauty ring mounting holes are raised. The beadlock ring has a flat mating surface.
Antho
Exactly. I dont see how thats going to work. The wheel has always had a flat mating surface. First time i've seen them do that stupid design.
XSTNKT
Michigan
It's a strange beauty ring design for sure. I would be really surprised if the mating surface wasn't all on one plane when the beauty ring is removed though. That's probably why they include new bolts (because the bolts for the beauty rings are longer).
Antho
@Xtinct Did you see OPs photo of the wheel with the ring off? I'm aware of the bolt difference but the beauty ring bolts arre actually shorter. I've ran beadlocks on all of my Raptors, Race truck, RZR etc.
ToadSmasher2K1
ToadSmasher2K1
Red Kingdom
I’ll take a beauty ring off again here in a few hours and get a better picture, more of a side profile of the mating surface. I’m pretty sure there was a significant difference
XSTNKT
Michigan
I missed that Antho. Thanks! I see the black sections of the mating surface are scolloped. A really dumb design. But, I'd still be really surprised if the actual mating surface (screw hole to screw hole) is on a different plane. I don't know how a beadlock would work if it was. That would take an incredible amount of machining to get those mating surfaces correct and even then, it would be weak. There's no way Ford would justify that extra amount of machining work, IMO. Really strange design. Must have been an intern in the wheel design department that did that....
