Ford Performance Bead Lock Ring Coating
BoostCreep
SoCal
Looks like it would work just fine, the tire bead sits on the flat surface outside of all the bolt holes, and the bolt holes are all on the same plane.
BoostCreep
SoCal
I’m thinking gloss black as well, but the 24R wheel is more matte or satin. So maybe match that?
I’m not sure if the 24R wheels are even going to look good without the new beauty ring.
The 24R wheels are the same finish as the 23R wheels. I just think it may look boring to match it exactly, I think it’ll look better with some color and sheen variation. Honestly I think gold anodizing them would look bad a$$!
Antho
One thing to note. My 37 package wheels show to use the same beadlock as previous years but the design is different. So you may want to double check. You may need the first set you posted. Thats the current problem i have. I have the 37 beadlock rings but they would look like crap on my 2024 37 Beadlocks wheels. There is no reason to have the extra material removed from the ring.
