Nice work. I'm interested in hearing more about the door handle swap, interior lights (cup holder, etc), and the security pack. Any details you can share on what you did is appreciated.
Thanks man.
The door handle swap is more of a personal preference than anything and a slight theft deterrent. I purchased a passenger front door handle with smart access and lock mechanism cap, had the handle paint matched and installed it on the driver side door. The door handle cap is the only portion of the door handle you need, ford just won’t sell the handle cap only. This eliminated the driver door lock and the handle is clean without holes and painted.
I installed a new cup holder assembly with lights, media bin light and glove box lights. These items were removed from our trucks after 2021 and can be purchased from Ford. John Forman makes a set of custom harnesses to plug these directly into the existing ford wiring to make everything light up. You will have to take the dash apart and center console to wire everything up. While I was in there, I did the HVAC control module swap with the digital readouts. Much better IMO. The media bin light was the most difficult part. I had to remove the media bin from the console to cut the hole for the light. 2022 trucks should have the hole already with a plastic plug to remove. 23s are a mixed bag. Job 1 build truck might have the hole already. Later built job 2 trucks like mine, won’t have it.
Same with the advanced security module. It can be purchase from ford and reinstalled. After installation, you’ll just need to make some small forscan changes to make everything work. This activates the motion sensors that are already in the truck.
Below all the part numbers for everyone. Shoot me a dm if you need the advanced security pack forscan changes.
- LC5Z-15K609-A advanced security module
- ML3Z-14A318-C Media Bin Light
- ML3Z-14A411-C Glove Box Light
- ML3Z-1513562-CB Cup Holder Light Assembly
