FullAuto
- Joined
- Oct 14, 2013
- Posts
- 1,042
- Reaction score
- 332
Well one thing I gather from this thread is zanemasterx sure loves the Gen 2's and seems to have tons of inside info........
Yep, the announcement of the Gen 2 sure opened the floodgate for all these forum noobs who think they know everything.![]()
@Huck, are you sure that's a misprint? I read that in a local magazine. The mag has two good photos of the new Raptor, so my impression is that both photos and text are from Ford. Here's the text as published (I've put the bit about the frame in bold text):
"2017 Ford Raptor
With all the changes in the Ford F-150 line-up in 2015, Raptor enthusiasts were shocked to learn that Ford did not unveil a Raptor in that line-up. Not to worry, the new Raptor will be available in the fall of 2016. The new body style and aluminum frame for 2017 sheds 500 pounds and dumps the V8 gas guzzler. The new high output 3.5L EcoBoost claims to give more horsepower and torque than the 411 HP, 434 lb-ft 6.2L in the 2014 edition. Also to be included are upgraded, "bigger" Fox racing shocks while maintaining the classic 35" BFG's with 17" wheels. Ford is also excited about a "torque on demand" transfer case and all new Terrain Management System for the 2017 Raptor. Electronic lights will be new as well with an all new LED lighting package and 360-degree camera system."
Okay, if indeed the frame is an aluminum alloy, that may well be a really bad metallurgical choice. Metals fatigue, and probably the most likely major part subject to metal fatigue on a high-speed off-road heavy-weight truck is the frame. When steel fatigues it bends before it breaks. When aluminum fatigues it breaks or shatters. A bent steel frame will allow you to limp home from Out There, but a broken aluminum frame is likely to strand you.
What's the hype about the "upgraded bigger" Fox shocks?
And doesn't a "torque on demand" transfer case mean that the new truck is AWD rather than 4WD?
