My truck is dead
Status
Not open for further replies.
Ni9mm
Florida
I got dibs on the headlights...
Should have bought a white one...
All kidding aside that bites a big weiney...sorry to hear it bro...keep us posted.
Dr_Pain
Louisiana
Any ways for you to remove the CAI and tuner and reflash before bringing it to the shop?
Sorry to hear Greg! Keep us posted
Squatting Dog
Squatting Dog
Kansas City, MO
Believe it or not roadside assistance was there quicker than I expected.. Which was a good thing because the truck was not in a safe area to get a ride home find everything and drive back (a good hour there and back). The truck would have been stripped/stolen/vandalized by then.
As far as the tuner, I could have reflashed stock tune, but would not been able to drive cycle the truck and it would be very obvious a tune had been on there..
I am hoping they are cool about everything..
-Greg
---------- Post added at 02:08 PM ---------- Previous post was at 01:54 PM ----------
Okay, shop called.. Truck is running great.. Antifreeze 1 qt low, oil level is a little high but okay. "can not duplicate problem. We are going to let it run and then drive again. As of right now you can pick up your truck this afternoon"
-Greg
Dr_Pain
Louisiana
-Greg
-Greg
What??? I sure hope you do an oil change and keep the oil or send it for analysis. This is MESSED up! Gremlins taking a bath and suds-ing up your crank case?
Donk74
Peoria, IL
Not to ask stupid questions but did they run it long enough to get the block and heads heat soaked? If it is a seal issue thermal expansion will likely play a role in weather it leaks or not. Along that same line "how" you heat up the motor could make a difference. letting it idol so it heats up slow and even might not result in a noticeable leak (yet) but a bit of spirited driving from cold may result in what you experienced Greg.
Hope they find something.
gordhunt
Thats ****** up you need to get the service manager involved
Sent from my Galaxy S3
Squatting Dog
Squatting Dog
Kansas City, MO
I am going to make sure they go thru it with a fine tooth comb.. That is after remove cai, tune, and drive cycle the ecm.. Then I will go back and get service manager involved.. Because what is going on is not right..
Thankful this is going on now and not during SNOball 500. Everything happens for a reason..
-Greg
jdowens1
Ford Senior Master Technician
Montana
Did you have an oil cooler failure. If you get an oil sample let it seperate in a container to see if its coolant. Coolant will sink and oil will float due to differences In specific gravity. Good luck with it.
Status
