MPT Tune Version 4
eclou
Houston
18 Raptor MPT PRX 93 tune, Costco 93 octane gas. Had one episode of "detonation/hesitation" occur accelerating onto a freeway at 3/4 throttle where I felt a backfire, loss of power, then the oil pressure gauge read zero. Pulled over, check for leaks - none, restarted truck and oil pressure was normal truck ran normal.
Fast forward 2 weeks and same problem occurred today. Visual inspection shows no obvious boost leaks, oil leaks, nada.
Any ideas?
kid icarus
Nintendo
The low oil pressure is a concern. Some here have reported that in both tuned and stock. You are best to go back to stock tune asap and keep driving until the issue reappears. Then, take to dealer. If you take it in now, you will get a denied warranty pretty quick.
Onemoosehorn
The low oil pressure is a concern. Some here have reported that in both tuned and stock. You are best to go back to stock tune asap and keep driving until the issue reappears. Then, take to dealer. If you jyju take it in now, you will get a denied warranty pretty quick.
Sasquatch.... where have you been?
eclou
Houston
the oil pressure is a glitch - reads zero after the stumble but as soon as you restart the engine it shows real pressure again. I read the DTC codes and its P0365 and P0389 for cam sensor error banks A&B. Resetting the DTC codes immediately restores normal operation even when the vehicle is in motion
Gdog
Colorado
I have a question for all you gotta get a tune guys. My friends running bully dog tunes on their powerstrokes motors tell me that their tunes are set to go into " limp mod" if the engine capacity set parameters are exceeded is this not achievable for the raptor motor? Would make perfect sense as opposed to doing engine damage.
91Eunos
Hill country, Tejas
Since the vents have changed, where are you Gen 2 guys who are already running a tune mounting the tuner/control unit itself?
Pics?
swanstreaming
Pics?
Mine stays in the glove compartment. No info on it I really need, and don’t want to clutter up dash.
dewalt
I got into a bad tank of gas. Knock sensors went nuts. Backed off a couple gears on the hills to keep things normal. Burnt half a tank and refilled with 93. It helped but took a couple tanks to straighten out. Couldn't tell driving but gauge was talking
