max tow weight ?
PlainJane
San Diego, California
i don't know about the sag or tongue weight, I would email Deavers on that question.
The tow tables make no since to me. Both the SCAB and SCREW have GCVR of 1200o lbs. Raptor weights ~ 5600 lbs. The Scab has a tow of 6000 lbs and the Screw has one of 8000 lbs. the numbers don't add up.
BIGDJE
BIGDJE
OC, CALI
yeah that does sound odd
just emailed RPG about deavers since they doing install next week
Icecobra
Gilroy Garlic capital of the world
Towing is critical not to exceede max tow weight. It takes in factors of frame, brakes, load on truck. Changing springs does not increase max towing capacity. Exceeding the towing cap can result in your insurance denying coverage in an accident. 8000 pounds max means just that. Including anything in truck plus passengers. If you want a tow vehicle buy a tow vehicle.
jrotts88
US
I looked at the specifications of the trailer you're interested in. You shouldn't have any issues with that trailer as long as you use a weight distribution hitch sized appropriately. I would recommend brake upgrades if you haven't done so. One of the weakest links on our trucks.
PCDan
Park City
Actually with a Raptor changing the springs does increase max towing capacity, because it’s only the suspension in the Raptor that lowers the towing capacity lower than a standard F150.
BIGDJE
BIGDJE
OC, CALI
i got rotors the size of my stock wheels with 8 piston calipers getting installed friday so brakes are covered lol
https://www.fordraptorforum.com/threads/r1-concepts-big-brake-kit.68471/
BIGDJE
BIGDJE
OC, CALI
thx i was thinking same thing still same frame as a normal F150 and my brake upgrade will stop anything lol
the HD deavers will be much more heavy duty then stock leafs plus i have RPG stage 3 getting installed with screw down fox bump stops to also help support
https://www.rpgoffroad.com/product/2017-gen-2-stage-3-rear-suspension-kit/
