Lets start modding. DRAGY results
1BAD454SSv2
1BAD454SSv2
HELL I ZONA
Cobb updated stage 2 . Garrett intercooler afe cold side pipe heat wrapped . BBK throttlebody. Cobb dry drop in filter. Msd coils . Ngk ruthenium plugs one step colder. 180 thermostat. Full race catch can and trans cooler . Full stock exhaust. Best e.t. in cool good weather 13.2 et.
1BAD454SSv2
1BAD454SSv2
HELL I ZONA
Weather was -700 ft density altitude this morning. Going to do a plug change today. Next week start doing dragy runs get a baseline. See if I'm still a 13.2 or better. Then Ams boost tubes. Video same stretch of road tires spun way harder. I should add only thing diffrent i recently had done , under Warranty 2 new iwe hubs and vacuum solenoid. Tech said front axles were engaged all the time . Tansmission Fluid and filter . Both axles F and R with Motul competition gear oil and transfer case fluid changed . Rotors turned new front pads.
K223
Florida
I can’t wait to hear how the AMS boost tubes work out. Hard to find real world performance data on them off the dyno.
1BAD454SSv2
1BAD454SSv2
HELL I ZONA
Didn't get a chance to swap plugs yet . Figured I would do a pull as this mod season begins again. I boost launched at 2000 rpm . 13.4 at 100mph. Off two tenths from my best overall. Air was decent my tires are at a pretty low pressure from normal. From the cool weather.
1BAD454SSv2
1BAD454SSv2
HELL I ZONA
I think my normal gas station is putting premium in wrong underground tank. filled up at a diffrent station same brand this afternoon. It's adding more timing than taking away. This morning when I did run I was still on gas from other station it was pulling timing not adding that much . I had my suspicions for a while. Something is definitely messed up at that station.
1BAD454SSv2
1BAD454SSv2
HELL I ZONA
I have been slacking off , on getting plugs changed and boost tubes on. Working on the Gen 1 today new CV axles , hubs , reinforced spindles , iwe eliminators. Dam these axles are built .
1BAD454SSv2
1BAD454SSv2
HELL I ZONA
Finally finished. The RCV axles are pretty heavy duty. New Timken Hubs . RCV iwe eliminators and SDHQ gusset spindles. Man when those lower ball joints finally pop loose its scary. I will torque wheels and clean up in the morning.
