GEN 1 Leak Or Seep after Ring and pinion regear 2014 Raptor .
Kaled
Hi guys hope all is well !
Today I’ve changed my ring and pinion and re geared to 4.56s . Drove the truck 24km and stopped for 10-15 min break for the break in period . Later on , I’ve noticed there is some sort of seep or leak passenger side rear end at the axle tube (pic) some sort of moisturized fluid . but I’m not sure what’s the causes of this ? And what should I replace axle seal ? Axle shaft ? Any OEM part numbers would be really helpful .
Truck is 175k miles / 279k km. Gen 1 2014
Here is a pic, if anyone could chime in would really appreciate it
GCATX
King Dingaling
Central Texas
I would hit it with some brake cleaner spray real good and see if it comes back. Maybe it sat with the shaft out and truck was at an angle or something.
Gumby
Nashville
Yes. should have???? I wouldn't say that. might as well..... yes. I don't have the part numbers. The seals and the outer Berings while you were there. would have been a great "might as well". It might be as GCATX says. Give that a try. Or pull the wheel and rotor get a look at the break shoes. They're going to tell the story.
GCATX
King Dingaling
Central Texas
Yes. should have???? I wouldn't say that. might as well..... yes. I don't have the part numbers. the seals and the outer Berings while you were there. It might be as GCATX says. give that a try. Or pull the wheel and rotor get a look at the break shoes. they're going to tell the story.
Ain't no shoes on a Raptor. Too fast, they would run smooth out of them. :)
TomDirt
Hesperia CA
He means parts #10-11, the "drum" brakes that make up the Parking Brake; (which is behind the rotor). There's also fresh oil on the front of the dust shield. Quickest way to figure it out is to pull off the brake caliper & rotor, and inspect if it's dry inside. Use a wire brush & brake cleaner (or something similar) to make it as clean as it was brand new.
Does the fluid have a smell? Old fluid smells like death, but if you compare the smell & feel of it to the bottle it came from, that's good to know.
Gumby
Nashville
I got all my stuff form Ron's machine. I called ask for Ron, the guy... Knows his stuff....I did every thing NEW, E locker, Carrier bearing, ring, pinion, crush delete, outer seals/Berings, every thing But the axels. and yes @GCATX New Shoes.
Kaled
Kaled
Thanks for the replies , I just brake cleaned the tube and any residue will update if this persist .
