KC HiLites Deals for you!
R
RSiWORKS
S.C.S. Michigan
KC RELEASES
INNOVATIVE MODULAR
“FLEX” SERIES LED LIGHTING
KC HiLiTES, the leader in off-road lighting, announces the availability of the industry’s most unique, modular and customizable LED platform.
Through a strategic design partnership formed with industrial design firm Heretic Studios, KC delivers on the goal of bringing the highest level
of performance LED lighting products to consumers worldwide.
FLEX Series LED lights allow consumers to expand and personalize their lighting setup as their needs change.
The KC Flex LED Series features five initial product offerings; Flex Dual Spot Beam, Flex Dual Spread Beam, Flex Array 10” light bar, Flex Array
20” light bar and Flex Array 30” light bar.
The FLEX Dual and FLEX Array 10”, 20” and 30” light bars are modular LED lights that allow users to join them together using special connectors
to expand the width or stack them to create infinite configurations. The patent-pending Flex Power Connection provides a power pass-through,
so regardless of how many you link together, there is only one wire harness that comes from the final assembly of connected LED lights.
Michael DeHaas, CEO and President of KC HiLiTES, Inc. commented, “There are a lot of exciting developments in the LED lighting arena and we want
to continue to lead it through innovation and performance. We’ve taken our 44 years of experience plus consumer feedback to create a truly unique
LED platform that protects our customer’s investment by allowing them to continue building on their initial purchase.”
The modular design of FLEX LED lights allows them to be joined together using available accessory connectors to expand
the width or stack them as desired to create infinite configurations.
The KC FLEX Series LEDs were designed in conjunction with Heretic Studios, an industrial design firm based in Utah.
This unique product line required a process of intense collaboration that involved tapping into Heretic Studio’s aesthetic
design edge and mechanical expertise while leveraging KC’s 44 years of proven optical, electrical and manufacturing experience.
“This project tested our abilities across all facets of industrial design. Designing a performance driven product
with this level of modularity in a compact size was something that only our joint teams at KC and Heretic could execute.
It’s truly exciting for Heretic to be a part of this strategic partnership and help create the FLEX Series platform that pushes
the definition of performance LED lighting,” said Jake Packard, CEO of Heretic Studios.
KC FLEX Series Products Include:
#271 KC FLEX Dual LED Spot Beam System - Includes two 20-watt Flex Duals and wiring harness
#272 KC FLEX Dual LED Spread Beam System - Includes two 20-watt Flex Duals and wiring harness
#273 KC FLEX Array LED 10” Light Bar Spot Beam System - Includes one 50-watt Flex Array 10” light bar and wiring harness
#274 KC FLEX Array LED 20” Light Bar Combo Spot/Spread Beam System - Includes one 100-watt Flex Array 20” light bar and wiring harness
#275 KC FLEX Array LED 30” Light Bar Combo Spot/Spread Beam System - Includes one 150-watt Flex Array 30” light bar and wiring harness
**Shipping in October 2014**
Contact RSiWORKS for more details
Kanakry
Great Lakes Region
As promised
R
RSiWORKS
S.C.S. Michigan
50" C SERIES C50 LED BAR & ROOF MOUNT BRACKET SYSTEM - F-150/SVT RAPTOR 09-14 -KC #378
MSRP: $1528.67
Contact RSiWORKS for your FRF pricing.
DETAILS
Light Bar:
LED: 3w x100
Total Wattage: 300w
Output: 27,000 Lumens
Beam Pattern: 12° Spot / 30° Spread
Color Temp: 6000K
LED Life: 50,000 Hrs
Housing: Extruded Aluminum
On-Board Thermal Management
Protected Against RFI / EMC Interference
Waterproof Connecters
IP 67 Rated
KC #338 – Single Light w/ Wiring Harness
Light Bracket Kit:
Easliy mounts in rain gutter for a clean, custom look
Featuring sturdy steel construction,
KC overhead brackets include all necessary hardware
Made in the USA
R
RSiWORKS
S.C.S. Michigan
"FLEX"
Why be like everyone else when you can be unique.
Features 10W Cree XM-L2 U2 LEDs
The FLEX Array LED light is an expandable performance LED light bar. Consisting between 5 and 15 cores, the Arrays are available as a standalone unit, complete with a side mount adapters and a u-bracket. The patented power systems allows multiple Arrays to be linked and even stacked together to create single and multiple-row LED light systems – the possibilities and applications are endless.
Contact RSiWORKS for your FRF special pricing.
IRONMAN
Well-Known Member
MICHIGAN
Here are my new Flex duals.
I built some amber covers for the Snoball run.
SilentShooter
Siesta Key, FL
Just received the free dual KC hooked me up with. Was trying to figure out how I was going to change the beam color. I might try that but coat the edges of the cover black to cut down on the light bleed from the sides.
Did you spray the rear wire connection with anything? Not sure how I feel about the open connections on the rear, kind of wish they made a cover over them.
was thinking two duals stacked per side is what I might go with. See how it comers to the KC 35w HID's I have now in which the lens covers annoy me with the light bleed and reflection due to the gap
