KC HiLites Deals for you!
IRONMAN
Well-Known Member
MICHIGAN
Just received the free dual KC hooked me up with. Was trying to figure out how I was going to change the beam color. I might try that but coat the edges of the cover black to cut down on the light bleed from the sides.
Did you spray the rear wire connection with anything? Not sure how I feel about the open connections on the rear, kind of wish they made a cover over them.
was thinking two duals stacked per side is what I might go with. See how it comers to the KC 35w HID's I have now in which the lens covers annoy me with the light bleed and reflection due to the gap
Yeah the lenses do bleed from the sides but it doesn't bother me too much.
I sprayed a di-electric grease spray all over the back connections to stop any kind of corrosion or oxidation.
I may try and stack another dual on top but these things give off a lot of light surprisingly.
RLTW
TX
Here are my new Flex duals.
I built some amber covers for the Snoball run.
Roger, long time no speak, I'm interested in what you'll quote a 20" flex for. Also what hood mounts did you use for the dual flexs? and do you have any pictures of them facing the truck head on or at an angle? Additionally I need to figure out what it would take to mount the 20" flex to my raceline bumper, I think they tabbed it for a 20" vis x.
IRONMAN
Well-Known Member
MICHIGAN
Hey chase, let me get back to you on these Flex.
Waiting on pricing from KC.
I used the SDHQ no cut hood mounts $110 +shipping on there site.
Raptor A-Pillar Light Mounts
Alternative Offroad also sells them but they are a bit more. Maybe contact him directly to see if he can do better cause SDHQ is pretty much set on price.
Alternative Offroad Ford F-150 & Raptor Hood Mount Light Brackets
Attached is a pic looking head on, the amber covers kill some of the light output.
These things are stupid bright.
As for mounting on the raceline I'm not too sure. You might be able to make a separate bracket that would mount to the kc bar then to the existing tabs.
Just an idea.
R
RSiWORKS
S.C.S. Michigan
3" C SERIES C3 LED BUMPER LIGHT PAIR PACK SYSTEM FOR FORD RAPTOR (2010-2014) - BLACK - KC #341 (SPOT BEAM)
SYSTEM INCLUDES (4) KC CUBE LED LIGHTS, (2) MOUNTING BRACKETS, (1) COMPLETE WIRING HARNESS
Features:
Fits 2010 - 2014 Ford Raptor
1,080 Lumens Per Light / 12w Each
Driving (spread) Beam Pattern
Easy Bolt-on Mounting Brackets to Factory Locations (No Cut / No Drill)
Included Wiring Harness works with Factory Uplifter Switches
LED Life-Span: 50,000 hours
Item #341
MSRP: $492.61
Contact RSIWORKS for your FRF pricing
[email protected]
3" C SERIES C3 LED BUMPER LIGHT PAIR PACK SYSTEM FOR FORD RAPTOR (2010-2014) - KC #342 (AMBER SPOT BEAM)​
3" C Series C3 LED Bumper Light Pair Pack System for Ford Raptor (2010-2014) with Amber Spot Beam includes: (4) C3 LED Lights, (2) Mounting Brackets, (1) Complete Wiring Harness (harness works with factory up lifter switches). LED life-span of 50,000 hours. Features: 1,0800 Lumens per light/12w each; spot beam pattern and easy bolt-on mounting brackets to factory locations (no cut/no drill). Fits 2010-2014 Ford Raptor.
MSRP: $509.27
[email protected]
:favorites13:
Deleted member 12951
Guest
Where do those brackets mount to exactly? I have the SVC Baja front bumper but looking at some side lights so just trying ideas.
IRONMAN
Well-Known Member
MICHIGAN
These brackets mount where you see the opening of the stock bumper, they most likely won't work with the SVC bumper.
You'd probably have to get a custom made bracket for that.
IRONMAN
Well-Known Member
MICHIGAN
They bolt to this bar here on the truck.
attachment.php
R
RSiWORKS
S.C.S. Michigan
KC-POD HID PAIR PACK SYSTEM
Ultra Bright 70w HID
Light Weight & Strong Carbon Fiber Housing
Spot Beam 976,000 Candlepower from Spot Beam
Driving Beam 462,000 Candlepower from Driving Beam
Contact RSIWORKS for all your KCHiLites FRF pricing
:hitit:
