KC HiLites Deals for you!
R
RSiWORKS
S.C.S. Michigan
The New and improved C-Series LED light bars
that are backed by KC's 23 year warranty.
C SERIES 10" - 50" LED LIGHT BAR COMBO BEAM
LED (3w): 10" x 20 | 20" x 40 | 30" x 60 | 40" x 80 | 50" x 100
Total Wattage: 10" = 60w | 20" = 120w | 30" = 180w | 40" = 240w | 50" = 300w
Output (Lumens): 10" = 5,400 | 20" = 10,800 | 30" = 16,200 | 40" = 21,600 | 50" = 27,000
Beam Pattern: 12° Spot / 30° Spread
Color Temp: 6000K (Clear LEDs), Amber LEDs
LED Life: 50,000 Hrs
Housing: Extruded Aluminum
On-Board Thermal Management
Protected Against RFI / EMC Interference
Waterproof Connecters
IP 67 Rated
Single Light w/ Wiring Harness
Contact me for your FRF pricing.
:rolleyes:
IRONMAN
Well-Known Member
MICHIGAN
RSIWORKS has all your lighting needs.
They also offer great discounts to FRF members.
R
RSiWORKS
S.C.S. Michigan
September Product Spotlight
LZR Series Cube and 4" Round
KC's LZR LED Series utilizes high performance LEDs in a efficient air cooled housing design. The Rugged Aluminum Turbine-style Diecast Housing provides maximum light output, distance, cooling efficiency and durability. Available in both 4” Round and 3” Cube for unlimited mounting possibilities. The LZR series goes unmatched for Lumens per watt and is backed by KC’s 23 Year Warranty.
LZR 300
KC's LZR 4" round LED light provides a 2,400 Lumen output with a total of 24-watts. Its distinct beam pattern is great to use in conjunction with factory headlights or other auxiliary lights. The 4" diameter housing allows to mount as a bumper light to upgrade your OEM 4" lights or aftermarket bumper lights.
LZR 310
KC's LZR Cube light has a Lumen/watt ratio of 130 with 2,600 Lumens and only 20 watts making it one of the most efficient LED auxiliary light. Its small profile makes it easy to mount where a traditional Halogen light wouldn't.
Alternatively, KC's 1311 comes as a flush mount kit to put the light 'in' a bumper or just about any flat surface.
Contact RSIWORKS for your special FRF discount.
:favorites13:
R
RSiWORKS
S.C.S. Michigan
Item:
#300 -- $482.91
-20% -- $386.33 +shipping
Features:
Output: 2,600 Lumens (each light)
Beam Pattern: Driving
LED: High Powered 5w CREE XLAMP XP-G (x 4)
Watts: 20w each light
Amp Draw: 1.67a each light
Voltage Input: 9-36v
Operating Temperature: -49 to 185 degrees F
LED Life-Span: 50,000 hours
Housing: 3.9” x 3” x 3.2” Cast Aluminum
Weight: 1.2 lbs each light
Waterproof: IP68 Certified
Shock Proof
KC Signature Turbine Air-Cooled Fin Design
Protected Against RFI/EMC Interference
Item:
#310 -- $378.07
-20% -- $302.46 +shipping
Details:
KC LZR LED 4" Round, Finned Turbine Design Die-cast Aluminum, IP68 Rated Housing
24Watt (6x 5w @ 80% Cree XPG 5000K Color Temp LED), 2800 Lumen - 50,000 Hour Life
Driving Beam Pattern for Additional Width and Distance to Maximize Visibility
System Includes Complete Wiring Harness, Switch Kit, and ABS Stone Guards
Designed in the USA
Applies to Pair packs only, offer expires September 30.
Please contact me via PM or email.
[email protected]
:happy107:
R
RSiWORKS
S.C.S. Michigan
KC offers some of the most affordable LED lights with outstanding performance
PLUS backed by a 23 year warranty.
Good morning FRF, I'll be offering special deals on all KC products today.
Please contact me for a price quote.
