Boss Hoss
This is the best one to use given my research and actual use. The JLT is too small to do a proper job. The unit should be mounted as far away from the heat source as possible to remove as much moisture as possible. I said this earlier--if you are going to the trouble to do this mod understand what is going on
The removal of this byproduct from the system by the catch can is important. Reason the system is the way it is now people have to be active in the maintenance of this and that would be a nightmare being part of the emissions system. USG would never go for it so it is routed back to be re burned water and all..
Mine depends on the weather--a larger can away from the heat source os good because it allows the volume of the larger can to take more moisture out. The one on this thread would be pretty worthless---do the research and don't just buy one because someone here did that did not do the proper due diligence.
