JLT oil separator
Nick@Apollo-Optics
I don't have one so I was just curious and wasn't sure how much of a pain it was to take off
Gotcha. It's not too bad. If you leave it for a little too long, it takes some muscle and it's a weird spot. I put Mechanix gloves on for a little extra grip and mine came right off no problem.
ironside
All over
Thanks it's on my to do list ever since I took my stock intake off and noticed how dirty the mouth to the throttle body was.
Blind1
Central Alabama
I installed my JLT just now & I had to stand on my Venom bumper to hook it to the intake & I'm 6'1". 1st Pic shows stock pcv hose. The 2nd & 3rd pic should help those whom considering in getting one a better perspective of how far back it is on the intake. I know you short people had to get a step ladder. .
svtippy
North Jersey
i just empted mine today for the first time i had it on for a week prob just under 200 miles and i cant believe how much stuff was in there IMAG0676_zps8192fe1b.jpgIMAG0677_zps1c57977b.jpg
BAJASVT
SE Michigan
I think it's great that this thing is catching so much crap, but emptying it every 300-500 miles is something I'm not willing to do. If it fills up that fast, the reservoir should be larger.
SuperRaptor
Seattle
Looks like a lot of the crap is appearing in trucks that have been ran in colder temps and it's that mocha color, which would mean a lot of moisture if I'm not mistaken.
BAJASVT
SE Michigan
Yes, for two reasons that perpetuate themselves.
1) More moisture builds up inside the engine during cold weather due to the temperature difference between inside and outside the engine... especially after the engine is turned off.
2) During the colder weather, the piston rings take longer to seat properly after startup. Without the piston rings seated properly, you'll get more blowby (more ambient air moisture past the rings and into the oil).
Short trips in cold weather don't help because the engine may never get warm enough to burn off the moisture/water.
These photos of what the catch can captures look dramatic, but this isn't really a big deal. I'm not saying the catch can doesn't help, but many engines go hundreds of thousands of miles without one and still run just fine.
---------- Post added at 07:18 PM ---------- Previous post was at 07:07 PM ----------
Similar situation w/o a catch can:
What is this white milky stuff under my oil cap?
