IWE vacuum system upgrades
Squatting Dog
Squatting Dog
Kansas City, MO
Saving gas/fuel economy is part of the reason behind IWE.. Instead of turning a locking hub, you turn a knob on the dash. And it disconnects hubs from drivetrain, which increases fuel economy.. I was being a smart ass.. Sorry
-Greg
Hockster
My 45ft Bluewater Party
Winchester, Va
-Greg
No you are a genie-ass!!! ha ha ha
beemerman
Worlds most famous beach
My 94 f150 4x4 had the old system no locking hubs, so you shifted into 4x4 by the transfer case. So the front axles,diff and front drive shaft always turned. That is why a lot of guys changed them over to locking hubs. Probably saved some on gas by changing them. Jack.
Ruger
Northern Nevada
-Greg
Greg, I got the smart ass thing. That's home turf for me! But I thought that the Raptor's front differential didn't turn all the time. And anyway, protecting the vacuum control system won't change how the system functions. I'm confused.
Russ
Squatting Dog
Squatting Dog
Kansas City, MO
It is protecting the weak diaphram inside the IWE from damage. If and when the diaphram becomes weaken/damaged it causes the splines (?) to wear/round off and eventually you loose 4wd. Which I suspect is what happened to bigj's raptor causing him to replace the IWE. Or the diaphram leaks or breaks leaving one or both sides engaged in 4wd all the time. And with the diaphram compromised the moisture travels through the vacuum system and damages the IWE solenoid. Now the whole IWE system would need to be replaced, which is no big deal for owners with warranties.
The open/unfiltered vent is the achillies tendon of the IWE system. The Raptors IWE is leaps and bounds better than eariler models, but it can be better..
Hope my rambling makes sense..
-Greg
