IWE vacuum system upgrades
FordTechOne
Detroit
I had the grinding effect due to the vacuum leak. I replaced the front hubs and vacuum check valve with the solenoid since I have 170,000 miles on the truck. Come to find out I still had a grinding sound...I figured it out to be the vacuum reservoir. Capping off the hose going to the reservoir solved the problem. Should have just done that first :emotions122:
So you capped off the vacuum reservoir so the hubs are engaged full time?
1BAD454SSv2
HELL I ZONA
I fought this for a while on my Gen1 , it would hold vacuum in driveway all day long , at certain speeds 45 ish and 75 , it would lose vacuum and grind or i would get loud pops sometimes when i did want to use 4wd , replaced hose's , iwe , solenoid . Finally gave in did full RCV axles and Eliminators . Never looked back.
DS550
Palm Beach, FL
I capped the tube going into the reservoir and the hubs are not engaged. Small hose (red circle) going into the vacuum reservoir is plugged. I probably won't be able to engage 4x4 right now since the check valve is holding the vacuum unless the solenoid releases the vacuum. Reservoir was ordered from Ford and I will have it Monday.
