Roger that Greg. Thanks.
I dunno. I see where you're coming from, but before I set out to make these changes, I'd want to ask the experts how many failures have they seen due to failed OEM lines (that weren't messed with otherwise)? How many IWEs have failed due to foreign material incursion/corrosion?
The official word on mine was that it was defective from the factory. If you believe that, and you keep in mind just how hard I beat on mine prior to that failure (lots and lots of desert time, a handful of water crossings, some beach/ocean time, etc) then that might be seen as a testament to how well the factory system works, after all.
I guess I'm wondering this: given the amount of work involved (not much, but some) AND the potential for new introduced issues with these changes, is it worth it? My (very limited) experience with "delicate" vacuum systems like this tells me they can be so sensitive that even a small change can bring the entire system down. Sucking thru a filter, for example, might require just enough vacuum over and above what is available, that you essentially have created a clog. What then?
Just thinking out loud Greg. I don't have any specific knowledge on this.
