Is idling bad?
KODIAK
So what’s contributing to the smoking? Bearing seals on the turbos? I can’t imagine it’s the motor itself in this day and age. I would have imagined Ford endurance testing accounted for this?
I remember the days when you shouldn’t let some particular small blocks idle long as the cam lobes weren’t pressure oiled, or some motor’s will burn up the valve seals and even lower tension rings would let a lot of blow by through.
Allegedly it’s leaky valve covers covered by the TSB. After they swapped mine on my 2018 they basically said just watch the oil level.
FordTechOne
Detroit
They don’t leak; the issue was with the integral PCV system allowing oil to enter the intake system, which resulted in smoke after an extended idle. The TSB has the dealer replace the valve covers with the updated ones.
K223
Florida
Yeah this sounds like old news at this point. This was a while back. So the smoking problem should not be at this point.
FordTechOne
Detroit
It wasn’t a recall, it was a TSB. So only people that noticed excessive oil consumption or idled for long periods would have had the updated parts installed.
Grizzly
US
You'll be fine. I live in AZ and in my previous job I had two EcoBoost F-150s that I put about 120k miles on each with no issues. Wasn't at all uncommon in the middle of the summer for me to turn it on at 4AM and not turn it of till 6-7PM other than once or twice to fill us for gas.
jabroni619
Which TSB covers this?
