Installed RPG Offroad Collar
NJSP117
New Jersey
I don't know where in NJ you are but I will be getting these in sometime this week. Ill try to install them either next week or the week after. I am going to try to do it without taking the shocks off the truck.
I'm down in South Jersey, outside of Philadelphia. How did you make out with putting them on? I see some people have now done it with the shocks on the truck...so maybe it's worth a shot.
Let me know if you were able to...might have to make the purchase and try it out....
---------- Post added 02-04-2017 at 12:08 AM ---------- Previous post was 02-03-2017 at 11:56 PM ----------
Here are a few photos from an installation today with the shocks on the vehicle. [emoji1417]
(1) jack stand
18mm combo
8mm on 1/4" ratchet
3/16 Allen wrench
Rubber mallet
Torque wrench
Floor jack
Aluminum block
external coil spring compressor (can rent this item from most auto part stores)
Maybe this is a dumb question, but what are the aluminum block and the rubber mallet for?
Didn't you use any air tools to compress the spring? Also, did you disconnect the A arm or the ball joints? Can you post a quick summary of the steps involved to do this with the shocks on the truck? That would be huge. Thanks!
Lee358
Wayne, NJ
I am going to be installing them this week, I was in Utah last week skiing and Im working all weekend. Hopefully I can get it done Friday. Ill let you know how it goes.
RPG
Orange County
I see Corey in his natural habitat.. Much different then in the UP.. :biggrin:
I'm still day dreaming about the 50 BMG. [emoji6]
---------- Post added at 09:16 PM ---------- Previous post was at 09:11 PM ----------
Good questions. I will be updating the installation instructions.
The mallet and aluminum block are to move the spring perch collar up once the coil spring force has been removed from it. I wanted to try a few different things and remove / loosen as few things as possible. So if you loosen the outer tie rod, you can easily tap up the spring perch with a soft hammer.
No I didn't need to loosen up the upper control arm to knuckle. But that something you can easily do to give yourself more clearance.
No worries. [emoji106][emoji2]
NJSP117
New Jersey
Excellent, thanks! I'm anxious to hear how you make out. I'm going to order them this week. I tried it on my Gen 1, but looking at the old pics, the Gen 1 springs were wound tighter and look a little thicker. I think the Gen 2 should compress a bit easier which will make the job a little easier on the truck. If I get them by the end of the week I'll put them on early next week when I'm off.
Hobert
Thanks to all who posted pics and info. This thread has sold me. I will be ordering soon!
96,364
60,271
tobychap
Latest posts
