Installed RPG Offroad Collar
JonasAtLethal
So I now have the shock collars on my truck. I gained just over 1.5" on both sides. I did the install without taking the shocks off. Just took my time and worked the spring compressors along with the jack on the A arm. Took me about 2-2.5 hr from the time I jacked up the first tire till the last one was back on the ground. I do have to say that the stance is perfect.
Thanks RPG!
I managed to do em with the shocks on today, just like you said, work em slow! I also took off the top a-arm bolt to make more room to work (not sure if it says that in the instructions)
sea2jet
Is it completely level?
sea2jet
RPG lift installed. Measuring from the fender lip to the center of the wheel, it's perfect. Same distance front and back. Thanks RPG. You nailed it, and, the quality is second to none.
MajorAR
Kansas
:patriot:
Very welcome. Glad you are happy!
Annnnd....your truck looks killer! Well done. :patriot:
robbys3m3
This is the first collar'd scab I've seen..looks great...would love to see more pics
u0104940
I will have mine done on next Tuesday, will post a before and after pic.
96,364
60,273
NTXRaptor
