Icon Multi-Rate Rear Leaf Spring Kit
06z
So Cal
Look at the end of the day, do your research if you're reading this thread. I'll rest my case with this simple fact: @svc and @RPG are easily two of the most trusted and well known aftermarket names in the Raptor community. There's a reason both of those companies who build the best Raptors out there only sell one brand of leaf springs with their kits, and that brand is Deaver.
SVC installed my icons.
06z
So Cal
Difference is that Deaver does right by any issues, you can see that in PLENTY of circumstances on FRF. Icon just tells you to **** off.
So you set your truck at option 3. You keep about 400 lb in the bed. Now you complain it sits too high. You should have 850 lb in the bed. do the common sense thing and set it to option 2, it's exactly what you need. I bet that is what icon is telling you. Another frf member had an issue with his icon springs and they took care of him.
MAMiller44
Tampa, FL
No, you flat out don’t get it dude. You’re not supposed to only run option 3 with 850 lbs.
Wojciech Gierczynski
Illinois
I barely have things in the bed besides basic light recovery gear.
just had my techs install the eibach springs last week and now have the icons en route.
It’s mostly a pavement princess with two or three times a month going through dirt upstate where I am currently building a family weekend home. Would like to preserve the OEM ride if possible, if not slightly firmer / planted. Leaning towards +2 setting unless y’all think I can get away with just +1 ?
Go with Option 1 in your case (the way they come) Option 2 will be too high if you dont carry at least 200-300lbs inside your bed all the time.
M_NorthRaptor
British Columbia, Canada
I know its probably in 1 of the 57 pages on the thread but did anyone have issues with swapping from option 1 to option 2? Just received my icon springs from 4WP and want to change to option 2 before installing them.
Any tips on the swap would be awesome to know. Looks pretty straight forward tho.
