Icon Multi-Rate Rear Leaf Spring Kit
Swarfworks
Michigan
At this point I'm not sure if @Swarfworks or @Mkarban are more excited to try out the Icon's as I am to read about it when they post a lengthy review with pictures. *hint hint*
Haha! I’m not planning on any more of a review. Unless they break in half tomorrow. To sum it up for me, I think Deaver is doing good because of their name. I think the Icons are better in every way and would never go with Deaver over Icon if I could go back. I’m a customer of both companies, so it’s just my unbiased opinion.
Swarfworks
Michigan
You mentioned stiffer than deavers - but still softer than stock on small bump?
Yes better than stock, and obviously no wheel hop like those crappy stock springs. And after some shock adjustments last night, I don’t think I’d use the word “stiffer”. I even like the way they ride on road better than Deavers. Crappy busted up Michigan roads at that!
BADASSRAPTOR
Well, something definitely to consider then. What size should I go with in Icons to match exact height with Geisers installed at the front?
Will I also need bump stops?
Slow6
AK
Update us on the coating after this winter so we know how it holds up. I mean I've pretty much made up my mind but I'd still like to know. If I do the leaf swap I might lay them all out and give them an extra coat or two of paint or something.
BlazinPond
ATLANTA / MSP
I plan to go with ICONS.
Any recommendation on where to buy and have installed here in Michigan?
Thanks in advance.
Kansas City
I'm planning to go with these Icons as well. One quick question and maybe a stupid one. Do you absolutely need to purchase an aftermarket bump stop kit with the Icon leaf springs?
Slow6
AK
You don't need to go with a Bump stop kit but it's recommended by Icon to buy the extension kit for factory bump. I would also recommend a rear bump stop mount since you are removing the block that has factory impact point. SDHQ has a nice looking one. It's what I'll go with when I do mine.
https://sdhqoffroad.com/collections...ts/17-current-ford-raptor-sdhq-built-bump-pad
Slow6
AK
Thanks for the quick reply! Just to calrify, you're saying to get the Icon extension kit and the SDHQ bump stop mount? Or is it one or the other?
You'd need both, when you take out the factory springs and block you loose the lower contact point for the bump stop.
