I installed Icon leafs w RPG track bars, but have a problem with the leaf retaining clamp in front conflicting with the RPG track bars. The underside of the clamp is pinned and I’m unable to remove it. What I need to do is grind off that head to remove the clamp and turn the pieces of the clamp upside down, so the cross bolt/nut is above the leafs and the underside of the clamp is tight to the bottom leaf.
Has anyone done this? If so, did you just grind off the head on the underside clamp OR are there other suggestions?
