Yukon Joe
BTW, did you get that passport application going?
Joe
Joe
Joe
A couple of comparison pictures with the ICON coil over beside the King. The most noticeable difference is the longer spring on the ICON. Both shocks are set up from the factory at recommended height settings.
Sure will be interested in your review on these shocks!!!
Figured I would start the install today with something easy like the rear shocks.
Well nothing is as easy as you think. The instructions read some sanding may be necessary to make the shocks fit. I started off with a dremel but had to go find the grinder to speed things up. I'll post a picture of how much material needs to be removed. Getting the shock in place was surprisingly no easy task, You will have to recruit a neighbour for a couple of minutes of help. I called ICON for some install tips and they were very polite and helpful. One thing they could not help me with was the torque specs for the shock bolts, they said that they are not allowed to give that info, so if anyone knows I would appreciate the info.
Oh ya, painted the rotor while I had the wheel off.
Both the King and the ICON are set up that way from the factory for the Raptor. the ICON just has a longer spring. Both shocks in the picture will be about the same as top perch.
I don't know if someone else posted but remember the reason the Icon's have a longer spring is it has an internal bumpstop hence longer shock body and is probably the reason for a longer spring.
