Help ASAP
RaptorAddict.com
You can quickly use lacquer thinner and them rub with a polishing glaze to recondition. This will not hurt the paint. The paint is too far cured for thinner to eat away at it in a short time. And DON'T use brake fluid.
2manytrucks
Florida
pre-soak that with WD-40, clean and then use a clay bar kit.... that should take it off and won't screw up your paint.
Dan06
The Dark Side of The Moon
I've (completely unintentionally) discovered brake fluid does a great job of taking off paint used to cover the areas of your scuffed up undercarriage. However, I wouldn't recommend it.
Az Scooter
Brake fluid is way too aggressive. Brake cleaner and Carb cleaner work great on fully cured paint for mistakes.
BIRDMAN
Birdministrator
Boston
I was gonna say carb cleaner. it's basically acetone though and that will f*** shit up if you're not careful.
J DAMAGE
NJ
I always used EZ-OFF oven cleaner to remove pin strips and over spray , never had a problem with fully cured clear coat being harmed,
6gun
Table Rock Lake, MO
Polishing compound and elbow grease. If you use Brake Fluid, you will likely end up with this ....
