Oil on lower spark plug only, not valve cover
2011reptar
okc
2011, 115k. Have had a slightly rough idle issue for a while. Among other things, changed all 16 plugs and 2000 miles later decided to pull them again to check gapping. When I originally pulled them, cyl 5 and 6 bottom plugs had oil on them on the end going into the combustion chamber. Anyway, all gaps were correct but I noticed the same two plugs had oil on them again. I confirmed this is NOT a valve cover leak, the outside of the plug hole is dry. Any ideas on what may be causing this and if it effects much? I understand the top plugs do most of the work and the bottoms basically just help with emissions? Anyway, not sure how to resolve this issue if someone knows what can be done, I hope it doesn’t require pulling heads.
pcs
milky way
any pics of the plugs? what other maintenance items have you performed? if you have no engine lights to point you in a direction, you can address the idle issue with easy maintenance items. clean the throttle body, MAF, and possibly use a top end cleaner. when you changed the plugs did you inspect the coil boots? 2 decade old truck going to need some tlc. all engines will burn some amount of oil. it can come from blow by past the rings, pcv stuck open, worn valve guides or valve seals, etc.
Mad Zeus
Florida
I didn’t have the rough idle . About half my lowers had a little build up the rest looked new . If your loosing oil I’d be concerned if not drive faster it’ll burn it off . Did you replace the coils & wires ?
2011reptar
okc
No pics, but the end was wet enough to bead up, almost dripping but not quite. It’s for sure oil, not gas which is concerning after such little mileage. Cylinder 5 and 6 only. I fired the parts cannon when I bought it about 3500 miles ago chasing the idle issue, and just to freshen up a 14 year old truck I knew nothing about - 8 coils, 8 injectors, 8 wires, 16 plugs, PCV, TB, O2 sensors, purge canister, MAF sensor, air filter, all OEM. Cleaned inside of air intake, did a seafoam treatment through crank case and through vacuum system, did an engine cleaner in oil before changing, reset KAM and did a relearn procedure in FORSCAN, did a compression test, scoped the cylinders and even popped both valve covers to look at the springs... All looks fine, just a little oil in cyl 5/6. No CEL, no performance or mileage issues, and no changes from before swapping out the old parts, just a slightly rough idle and sometimes almost dies when shifting into park, will dip to 200rpm and then back up only when stopping and shifting into park.
Right now I’m more concerned with the oil situation than the idle as I understand the Raptor variant of the 6.2 has a more aggressive overlap than the one in the f250, so a little choppy idle is normal and I may be chasing ghosts there. I just want to get ahead of an issue before I get stranded somewhere considering the amount of oil I’m seeing on the plugs. I should add the top plugs were all spotless. According the maintenance records they were changed about 10,000 miles ago… they looked newer. Most of the other bottoms looked fine as well. Of all parts changed, 2 coils had bad resistors, but otherwise sorta think I wasted my money replacing things.
I guess it would have to be guides/seals or getting past rings as you said. I wonder how long this can be lived with before it gets much worse or ends up causing other issues.
pcs
milky way
stock raptor cams shouldn’t have any “chop” bc they have to pass emissions. also, plugs shouldn't be spotless after some use. they should be turning light brown. if it really bothers you, maybe a compression/leak down test can address any concerns with engine health. i had a similar issue with the engine wanting to stall randomly at idle and what fixed my issue was a new fuel pump. your truck over 2 decades old its going to have some quirks.
FishFreak
Sacramento, CA
As pcs said, the leakdown test will let you see where your leakage is coming from, rings, coolant, intake or exhaust valve, so by elimination, if the rings aren't blowing by worse in those two cylinders, then it's from the valve train. You said you did a compression test - what were those two holes like vs the rest of them? I'm guessing you also took pics with the borescope? If you did, what did those piston crowns look like? Any signs of ring wash?
Can you explain how you serviced the 'purge canister'? Did you replace it? This is for my own info for my 2 years new to me 2014, now with 140k miles, idles and runs fantastic, knock on wood, and I'd like to service everything like you did.
2011reptar
okc
Will look into a leak down test to at least confirm origin. I’m betting it’s exhaust valve since it’s the bottom plug but we’ll see soon.
I was lazy and only compression tested the driver side, but all 4 were within a few psi of each other. Pistons and cylinders looked good, still plenty of crosshatching, cylinder head had a little oil residue but nothing crazy. Pics attached, didn’t take too many with the borescope but general idea, you can even see the oil on the threads.
Yes, I just replaced the canister. It’s a few bolts and super easy to do! Theres a few good YouTube videos of it, maybe 10 minute job including full disassembly of the intake hose etc.
bwep
Mass
Theirs been some talk that the 6.2 can break a valve spring.
I would be pulling valve coves to take a peek.
Mad Zeus
Florida
I saw a lot on that problem. Wouldn’t wish that one on anyone. That last picture reminds me I’m do for a colonoscopy. Lol
