Wiring Innovate AFR Gauge help
igotaRaptor
igotaRaptor
west grove, PA
ok so does it matter if I pick up signal from #8 cylinder compared to # 1 only reason I ask is #8 is a lot closer and don’t have to run it all the way up to the front right injector
igotaRaptor
igotaRaptor
west grove, PA
Just have to run the o2 harness and calibrate the sensor and tap into the injector but it’s in and it works!!
  • IMG_2515.mov
    9.9 MB
igotaRaptor
igotaRaptor
west grove, PA
For the 02 sensor I ended up buying the glow shift band clamp 02 sensor **** thingy and it killed me to have to drill into my stainless works long tubes but it turned out not that bad, started the truck drilled it with my step bit and all shavings blew out thank to exhausts help.
The Car Stereo Company
here, on frf
Would you also happen to know what Pulse Per Rotation? I known asking for a lot
i dont have that info unfortunately. but if you have access to a decent scanner, it might be able to tell you. i can connect to the wifes truck tomorrow if needed and take a look. however you shouldnt need that info
