Heated Wheel Retrofit
BoostCreep
SoCal
For those that only swapped the SCCM and are using the “soft button” where does the soft button go? I just realized there’s no climate section anywhere on my Sync display.
xlover
Boston
You have to use forscan to swap your apim to the “unreal theme” which is a different layout similar to the touch only displays in fords portolio and thus has a climate bar on the bottom.
Edit: for what it’s worth I did the full climate unit as I preferred the standard layout.
cfmistry
Maryland
You have to upgrade to the Unreal theme, then enable the climate bar, then add the heated steering wheel icon.
DougDimmadome
East PA
Has anything changed as far as inconsistencies with programming the digital dial HVAC module? I bought the non digital version since its seemed to be a trouble free install back in May when I ordered everything. The plan is to finally install it this week, but if there is a tried and true way to get the digital readout HVAC working with forscan, I may just order those instead.
I can't seem to find info on whether it's still a crapshoot or not getting that version up and running without dealer level diagnostics.
I installed mine with forscan and it worked just fine
96,401
60,331
JaytheGreat90
