Heated Seats Not Working
Beinkounter
Riverside, CA
was this ever resolved? Mine also don't work, light comes on, but after 15-20 minutes the seat is barely warm, not even close to hot.
Littlefx4
OP is saying his doesn’t work, period. Yours does; however, they don’t get as hot after some time. Assuming this is on the highest level, correct?
edit to add…this thread is damn near a year old. I certainly hope it’s been resolved.
pnwobrigade
WA
Made a separate thread but related issue. My heated seats and climate control doesn't come on via remote start but work fine once vehicle start button is pressed. All applicable menu options are enabled to Auto and selected under the Remote Start option. Seems to be some funkiness with these?
Littlefx4
Try enabling all applicable menu options in your guest profile and see if that’ll affect anything…
Littlefx4
Also, is it via the fob, Ford Pass app, or both?
edited to add…just saw your thread where you’re using the FOB. Is it doing the same w/ Ford Pass App?
pnwobrigade
WA
Haven't tried with the Ford Pass App, I will verify that shortly.
pnwobrigade
WA
Just spitballing, is it possible your fobs are set to a specific profile…
So interestingly enough this might of worked. I reset my remote start settings and setup my profile to a specific key (which wasn't done by default). If I remote start via Ford Pass or FOB the HVAC now kicks on and the heated seats on low, no lights are on during this time but you can feel the seat somewhat warm and defrost comes on. So something in those changes worked. Appreciate the advice there!
Littlefx4
Glad you got it worked out & that it was something simple.
