Header installation with supercharger
EricM
OHIO
There are SS bolt kits for the 6.2L but I don't think anyone sells a SS stud kit.
You are probably going to have to one-off that setup. If you have friends with machine tools, or have your own you can make whatever you need. Lots of old lathes around here in people garages given the machine tool history of Cincinnati so stuff like that is easy aropund here- just give them a drawing and they make it.
SS bolts would be OK too, especially if you never plan to remove them. Studs have the advantage of protecting the threads in the head since they only pull on the head threads during the torqueing of the nut- no rotation against the head thread like a bolt does as you torque it.
KYmxracer52
KYmxracer52
Central KY
Is there any cons to going with 1-3/4” headers over the 1-7/8”? I can’t find any reading material on this supporting either direction.
EricM
OHIO
N/A? Yes. Go big with a N/A engine.
With a Whipple? No. A twin screw will cram the air through whatever exhaust you have w/o issue. A slight undersize on the exhaust piping will have very little consequence on overall power. The smaller pipes are easier to install too.
pcs
milky way
how far out are you planning on revving the engine? the smaller diameter will likely make more power lower in the rev range while the larger headers will make more power in the upper range. if you are keeping the stock rev range you might not see much gains going to the 1 7/8.
KYmxracer52
KYmxracer52
Central KY
I don’t rev it out real high. I’d much rather have all the torque I can get. Found out today that Kooks has the headers in stock, however it’ll be around 4 weeks or so before the Y pipe is built. Anyone know of a vendor who has a green catted Y in stock?
pcs
milky way
you check flea bay?
KYmxracer52
KYmxracer52
Central KY
Ended up ordering everything from JDM. I checked that set on eBay and it looked to be pretty old by the part number. Although I think he was wrong, he said that pipe wouldn’t fit a 2014. Now I just need to order a few misc parts that I’ll need.
I know it says Kooks includes gaskets, but what’s the best quality one I can put back on. Since both sides of the OEM has failed, I’m not sure it’s the best. Does one need to put RTV on with the gasket or is that just overkill? I could see it helping to hold the gasket while putting header into place.
EricM
OHIO
As long as the threads into the head is a match, those studs should be fine.
I'd run the Kooks gaskets. They should be a stainless steel multi-layer gasket.
