H&M racing design long travel kit
Status
Not open for further replies.
C
canamds450
Any updates?
Waiting for the pictures to continue building upper shock mount bucket with railmount at the top.
I got the fenders, those fender are lie wet cardboard, edges are so fragile.
Do i need it to paint them before installation or after installation?
Hope they fit flush, +3" kit with a +3" fender -34offset stock fender.
I think tires will be 1/2" out of fenders 12.5" wide bfg. If i use 37" 13.5" wide toyo mt tires going to be out 1" then
1ntheoc
Orange County, CA
You'll want to "fit" the fenders first. You'll most likely need to do some trimming and sanding (possibly even adding) to the fenders to get them to line up nicely. Once you're satisfied with the way they fit, remove them and have them painted.
BearLeeAsian
Dallas Texas
Wet cardboard is an interesting way to put it. It did travel a long way from the looks of it and it looks pretty good.
C
canamds450
As i have seen on some pics for the build, looks like is made from tube crossed sxs
ntm
Alberta, Canada
If you intend to use tubing for the shock mounts, make sure you have a piece of plate between the end of the tubing and the frame.
Something that is common practice and knowledge here, but might be an unknown to you.
C
canamds450
Yes, edges need to be gusset.
I think tube is easier to work with, only thing it need to be gusset.
C
canamds450
Checking the suspension bottomed
Lower front pocket has a lip and limits its up travel
So i cant reach the recommended height of upper shock mount support without grinding lower a arm front pockets
At this point if i dont grind it, suspension remains within 1" of travel left until bottoming out
Upper a arms clearance
This is the only tool i have, my lever from my iphone app. i ordered one magetic digital angler lever from amazon
C
canamds450
Just ordered this similar as the one i got from the pictures they are helping me with
Status
