H&M racing design long travel kit
Status
Not open for further replies.
Skyline
here's some pics of my truck...
ah yes, someone with a regular f150... I hope to someday go as far as you with my f150. Awesome fabwork, make sure to post pics when finished :popcorn:
C
canamds450
You can see what i'm talking about when I mentioned plating your frame. Also there's a pic of the lower engine cage and one with the hood up. I hope this helps.
Hey great, kevin will semd me a similar pic to make it on my truck
What is the meassure from the front mount to first tap pocket? I got 9 1/4"
Gave me around +7degree caster on my truck
Kevin from h&m racing design told me to do this, technicalky i did not understand what he meant to do
12.750 inches off top of frame to center of upper shock bolt on the front bypass shock. Bottom the shock with only a 1/8 washer in between the shock body and full collapse. Then set the travel so the front shock is at that measurment. Remember everything is built fully compressed for that
measurement.
C
canamds450
Installs looking better. For awhile there it looked like you had so much caster the truck was going to turn like a road grader.
Yes, almost getting build done hopefully by the end of next week.
Caster were like that, because of the stock mount on place. Right now i m close to 7 degree on caster, it needs to be at 8 7/8" from frame mount.
It require to mod brake lines pumps to move it a bit forward for the ideal position. i stayed at 9"
Status
