H&M racing design long travel kit
Status
Not open for further replies.
SDHQJASON
Gilbert, Arizona
This scares me.... I think you need to have a talk with the guy installing your kit. The coilover mounts should definitely fit better than this....
ntm
Alberta, Canada
Just weld that gap up :ROFLJest:
3 " wheel spacers on each side might have been the way to go after all. Safer !
C
canamds450
welder just tapped the mounts just to see how is going.
next week i m getting a digital beam lever to make sure all my angles and measures are good to go.
i dismounted everything to get them painted.
C
canamds450
FIY - the recommended spec range for caster is 4.0 - 4.3. You are almost double that.
i just ordered a beam angle digital lever, will that help to make sure the recommended caster is around 4.0 to 4.3?
i will move a arms a bit forward, where it supposed to be and upper mounts going to be measure with digital angle as well. probably on wednesday, i will be having that lever on my hand.
so i going to make sure all the measure i got will be exactly the same with the truck flat and lever.
it is a magnetic lever got it at amazon
take a look of the caster how is doing right now
C
canamds450
While i wait for the beam digital lever to arrive, it gave me time to paint the lts kit
C
canamds450
So you painted the uniballs?
:snoopfacepalm:
Yeap, those guys there. They paint all my heavy equipment and cargo trucks, paint department. I Told them to cover that part and they didnt, but it goes away easily.
C
canamds450
What can you note there?
2.5"Coilovers
32" full extended
21" full compressed
3.0" bypass shocks
21" full compressed
33" full extended
Status
