h&m racing design ford raptor long travel kit (clean post)
C
canamds450
They painted the fenders on the truck, so there are some paint spots on the rubbers seals and my hood was ruined with that cheap paint they used, did not mached the oxford white paint at all
C
canamds450
Hey wen i use the 4wd the front axle has a cracked sound and it is a new front axle. Could be because of the extremely high ride heigh of my truck?
SDHQJASON
Gilbert, Arizona
A cracking or clicking sound could be a number of things. Typically it is the IWE engaging or disengaging. Check to make sure your 4wd vacuum lines are hooked up correctly. It may be that the IWE has gone bad due to improper use.
C
canamds450
When you say "they" who do you mean? I thought you were doing this mod at your shop.
I meant they because i had to sent it to a paint chop. Here i just pain my tractors dozers and trucks from the conpany. Looks like it qas painted here. Poor paint job, well it was only $250 paint job
---------- Post added at 05:45 PM ---------- Previous post was at 05:36 PM ----------
Yes, kind of something like that. Most of the time i use rear lock diff, but this time i was towing my rzr when i needed 4wd for a slippery uphill.
Going down was a problem since i lost abs, tcs and downhill descent control.
Let see how long will take to keep that lts kit on my truck, probably i will be removing it and get the one that you sell.
C
canamds450
At 17" almost 17" of extended suspension travel. Coilover are rubbing with UCA
C
canamds450
Noted Water is getting into my airbox side entry. Just by driving the truck on the rain.
Raptizzle
FYT
Southern CA
I would seriously consider sending your truck to the US for a proper install and to address the issues you're having. I'm sure it's pricey but you have a substantial investment in the truck and it's a shame to see it go down the drain so to speak.
